How to Overlay/add shapefiles that don't have the same number of polygons
1719
12-20-2022 11:54 PM
MarianaReyes
Hello everyone I'm having a hard time trying to overlay my 3 shapefiles. for instand what I'm trying to look at are the LULC changes. For instance I was hoping to be able to do this
Raw data:
Shapefile 1 - Year 2007
OIDTYPEID
1Forest100
2Shrub 200
3Grass300
4Mudflat400
Shapefile 2 - Year 2018
OIDTYPEID
1Shrub020
2Forest010
3Mudflat040
4Mudflat040
Shapefile 2 - Year 2021
OIDTYPEID
1Forest001
2Shrub 002
3Grass003
4Grass003
What I want my Shapefile to look like:
OIDTYPEID
1Forest -Shrub- Forest121
2Shrub -Forest-Shrub212
3Grass-Mudflat-Grass343
4Mudflat-Mudflat-Grass443
I cannot make this poutcome because the size and and number polygons in each shapefile are different. I want to add the ID number to see th changes. I already did the raster to check the rate of change using this raster equation:  ("current raster"-1)*9 + "previous raster" -1 but its hard to put all three togethger to to see which parts changed (in terms of visualization. Thank you in advanced
MarianaReyes
Raw data:
OIDTYPEID
1Forest100
2Shrub 200
3Grass300
4Mudflat400
OIDTYPEID
1Shrub020
2Forest010
3Mudflat040
4Mudflat040
OIDTYPEID
1Forest001
2Shrub 002
3Grass003
4Grass003
OIDTYPEID
DanPatterson
MVP Esteemed Contributor
In raster world use
Combine (Spatial Analyst)—ArcGIS Pro | Documentation
it produces a unique combination of the classes
... sort of retired...
Robert_LeClair
Esri Notable Contributor
If you've got the Image Analyst extension to ArcGIS Pro, then the Change Detection in ArcGIS Pro is your best best.
RE:  the field calculation of text to integer based is pretty easy.  For example - int(!year2007!) + int(!year2018!) + int(!year2021!)  Output is written to a short integer field.
