How to merge two attribute tables
8505
11-22-2023 03:54 AM
NeilGodfrey
Hi
I have two attribute tables, one (the master file:A) has some additional fields compared to the other table: B), and I want to add the data from the B into A
Can anyone tell me how I do this?
many thanks
Tags (1)
DanPatterson
MVP Esteemed Contributor
Append (Data Management)—ArcGIS Pro | Documentation
Merge (Data Management)—ArcGIS Pro | Documentation
depending on what you want, but
Map attribute fields—ArcGIS Pro | Documentation
field mapping should be used to provide guidance for common fields.
... sort of retired...
DanPatterson
