How to know if an ArcGIS Pro bug has been fixed?
744
02-26-2026 04:54 AM
Bud
Legendary Contributor
When reading this bug report, it’s not clear if the bug has been fixed or not:
In ArcGIS Pro 3.5, Calculate Field does not honor selection or layer filters when using SQL as the expression type on file geodatabase data
https://support.esri.com/en-us/knowledge-base/calculate-field-does-not-honor-selection-or-layer-filt...
Article ID: 000036268
I could make a guess based on this wording:
This issue will be addressed in 3.5 Patch 1 (3.5.1), planned to be available the first week of June 2025. Until a patch is available, the software update service will be disabled in ArcGIS Pro. Customers who understand this issue and the workaround can download ArcGIS Pro 3.5 from My Esri.
But I’m wondering if I’m missing something. Why isn’t there a status indicated? I don’t work in I.T., so my MyEsri account isn’t linked to my organization’s GIS admin account, so I couldn’t check the bug status there.
DanPatterson
MVP Esteemed Contributor
ArcGIS Pro 3.6 Issues Addressed  page 22
BUG-000176644
The Calculate Field tool does not honor active selections and layer filters
when using a SQL expression
or on the Support site
BUG-000176644 for ArcGIS Pro
status now says "fixed"
... sort of retired...
DanPatterson
BUG-000176644
AyanPalit
@Bud Customers who report the BUG get notifications at each status change. You can also have your organization attached to track an existing BUG. As you noted, this can be done through representatives with MyEsri access.
Latest status on BUGs can be found using steps noted by @DanPatterson
  • Start at Esri Technical Support webpage
  • Search for the BUG
  • Get the publicly available status on the issue and related info. Note that you may not get any results on certain BUG numbers as they are not yet public
Ayan Palit | Principal Consultant Esri
RichardDaniels
MVP Regular Contributor
FYI - ArcGIS Pro 3.5 is now at Service Pack 6, these SPs are cumulative, so you only need to download SP 6 and apply it to your ArcGIS Pro 3.5 installation. The ArcGIS Pro 3.5 Issues Addressed document is updated with each SP release.
