How to keep grid outside map frame when using a clip layer?
7044
14
12-26-2023 03:37 PM
CayerA
I'm making a series of maps for a fire district, one map for each station response area. I want to include an address hundred block grid, but when I create a custom grid, the ticks and labels conform to the shape of the clip layer (image). Is there a way to have a custom grid that stays on the boundary of the map frame?
CayerA
This is brilliant! Thank you.
jm10
In the Contents Pane, click the Grid Properties. There is an option in the Map Grid Options called Grid Boundary. Uncheck the circled box to not clip the grid to the clipping shape
JesseWickizer
 Unfortunately this option isn't available for custom grids.
CVCJ
Thank you, this helped me as I'm not using a custom grid.
PaoG2024
December 2024, almost a year after your question, and @esri hasn't been solved this basic function that has been around for a long time on desktop.
