How to identify gaps in a linear network
3144
11-23-2021 09:22 AM
Nick_Vague
I have a polyline layer of cycleways and am looking to identify gaps in the network, so if cycleway A stops and then Cycleway B starts again in 100m i'd like to be able to highlight this.
Essentially it is like a nearest neighbour but i want to analyse the features contained within the same layer. Is this possible? I've tried a few tools and checked online but can't find anything that seems to answer my problem.
Thanks
DanPatterson
MVP Esteemed Contributor
Feature Vertices To Points (Data Management)—ArcGIS Pro | Documentation
maybe using the endpoint option, so two points would be side-by-side if the end points of the polylines are disjoint/not connected
... sort of retired...
curtvprice
Have you considered building a geodatabase topology and setting a rule to tag disconnected nodes (dangles)?
Or (@DanPatterson  suggestion) running Feature Vertices to Points, asking for Start and End points, then Near the points to themselves and finding all points with NEAR_DIST > 0?
