How to generate service area without consuming credit as I have millions of locations so using credit won't be possible?
3079
05-01-2024 01:39 AM
SangamRaj
DanPatterson
You would have to purchase the Network Analyst extension as an addition to ArcGIS Pro
An overview of the Network Analyst toolbox—ArcGIS Pro | Documentation
... sort of retired...
SangamRaj
Hi DanPatterson, this Network Analyst extension is consuming credit 0.5 per service area. I want to solution which doesn't consume credit. Please suggest possible options.
BobBooth1
From the doc: "The following Network Analyst tools will consume credits when the network analysis layer references ArcGIS Online as the network data source, or when you use a server connection to logistics.arcgis.com."
https://pro.arcgis.com/en/pro-app/latest/tool-reference/appendices/geoprocessing-tools-that-use-cred...
To avoid using credits with Network Analyst, you will need to obtain street data for your area of interest, create a network dataset on it, and run your analysis on the local data.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/network-analyst/an-overview-of-the-network-d...
TaslimaKhandaker1
Hello Dan,
I've tried this process. I've trying to use the closest facilities api on the developer portal. I've hosted my network, however it is still consuming credits?
