How to find differences between the same two point layers
676
03-03-2026 08:03 AM
NancyBracken
So I am still learning and I need some help. I have two of the same layer which is Address Points. I have one more in the one layer than the other, how can I find where the difference is between those two layer.
DanPatterson
MVP Esteemed Contributor
you could try
Add Join (Data Management)—ArcGIS Pro | Documentation
assuming that you have a common field or fields in both.  Pay attention to the parameter
Keep all input records
... sort of retired...
RPGIS
by MVP Regular Contributor
I think the erase tool may help to some extent also. That might indicate which one is not the duplicate but I would need to test that.
Another option is to run the frequency tool on both datasets and do a comparison that way.
Otherwise, assuming the addresses have matching values, @DanPatterson recommendation would be best.
Robert_LeClair
Esri Esteemed Contributor
The Feature Compare (Data Management) GP tool compares two feature classes or layers and returns the comparison results.  It works against geom etries, attributes, schema's and more.
