How to Export a map as an interactive PDF in ArcGIS Pro
1444
09-05-2023 08:05 AM
wlsgudwls123
Hi, I'm trying to export a map in ArcGIS Pro as an interactive PDF. I followed steps from ESRI and exported the map as an interactive PDF. How To: Export a Map as an Interactive PDF in ArcGIS Pro (esri.com) Thing is... I'm using Nuance Power PDF Advanced instead of Acrobat Reader. Does anyone know how to activate interactive PDF from ArcGIS Pro in Nuance? Or export PDF differently so I can activate the map in Nuance?
DuncanHornby
MVP Notable Contributor
This sounds like a Nuance Power PDF issue, have you tried contacting their support page?
