How to delete recent project history
4090
06-22-2015 02:26 AM
DevlynRobson1
I deliver training on Pro and recently discovered that because of my Windows login, the projects were being loaded into the recent project history, even though I deleted the training data which had been used to generate the projects (so technically they are not saved on disc anymore).
Is there a way to delete recent projects from the Pro start up? I don't want to confuse the learners when they start making their own projects with the same names.
Robert_LeClair
Esri Esteemed Contributor
Hi Devlyn - this question was asked about a month of so ago I believe.  The solution may be found here:  Re: how to remove ArcGIS Pro recent projects form the start menu?
