How To Convert TPK(tile package) file into shape file format ...???
3792
09-03-2017 12:21 AM
shashikalaKala
i have a TPK file and i need to convert as a shape file...anybody can help me out in this?
DanPatterson_Retired
There is no conversion mechanism
You can extract a package  then you have to convert the contents contained in the package using the usual means.
shashikalaKala
Dear Dan thanks for your kind reply.....
if possible could you please explain  in detail.......? i have extracted layers by using extract package tool..now i can not create shape file manually ..so i need shape file format with respective feature....how can i get...if i use raster to vector conversion ..can i get  proper shape file?
thanks in advance
conversion tools contain the options for converting files.  A simple raster can be converted to a shapefile but you will not have much luck with complex ones or files like DEMs
