How to convert .pitemx file? without access to portal connection
2586
09-16-2023 05:53 PM
Labels (2)
SatriaDwifiantoPutra
Hi, I'm a beginner in ArcGIS Pro.
I need some help. I already do all methods available on online and other resources, but not solutions.
The problem is,
I downloaded a pitemx file and tried to convert it to a polygon shapefile or anything. But, when I tried every available tool on the geoprocessing tool, it never showed up as a selectable file (on the catalog panel).
1. I also can't make a connection to the portal (data sources).
2. the pitmex file is uneditable.
3. the pitemx file if I look again, is in PNG32 format.
4. the pitemx file has an attribute table.
5. even when I make a save as a layer (lyrx), still can't do anything after that.
Please, if anyone can help me. I really need to convert the data. Hereby, I submit multiple photos and the pitemx file that I mention.
