How to calculate 3d intersection using SQL Query
1671
04-17-2024 02:00 AM
BattulgaGantulga
Hi, I try to Intersect 3d polygon and Lines on SQL Server. But it's not working. Please support me on this issue. How to correct dynamically calculate intersection of 3D Line and Polygon?
I wrote following SQL Query.
SELECT
    P.*,
    L.Shape.STIntersection(P.Shape).ToString() AS IntersectionPoint,
    L.Shape.STIntersection(P.Shape).STLength() AS IntersectionLength
FROM
        SELECT
            geometry::UnionAggregate(Shape) AS Shape
        FROM
            Geol_LicenseBoundary3DA
        WHERE
            Layer LIKE 'LB_XXX%' AND last_edited_date IS NULL
    ) AS P
JOIN
        SELECT
        FROM
            Geol_DH_ActualTraceL
        WHERE
            HOLEID = 'UGDXXX'
    ) AS L
ON
    P.Shape.STIntersects(L.Shape) = 1;
Thanks
Tags (1)
JesseCloutier
Esri Community Manager
Thanks for bringing your question to Esri Community, @BattulgaGantulga.
Which ArcGIS product are you using? I'd like to help get this post moved to a more relevant Board where it's more likely to be seen and responded to by members with relevant expertise.
Jesse Cloutier
Community Manager, Engagement & Content
BattulgaGantulga
Hi Jesse Cloutier,
   Our Database is SDE Spatial Database on MS SQL Server. We are using ArcGIS Products (ArcGIS Enterprise, ArcGIS Pro)
Thanks
JesseCloutier
Thanks for following up, @BattulgaGantulga. I've moved your post to our ArcGIS Pro Questions Board. All the best!
Jesse Cloutier
