How to batch layer updating?
973
11-20-2024 09:16 AM
Labels (3)
Davec43
Currently I have over 100 feature layers that need to be updated that all have different names. Annually I take a layer that covers a large geographic area and trim it and separate it into smaller layer files with using a select by location.
Is there a way to automate this?
DanPatterson
If the geographic bounds have a named attribute then you may be able to split it into its constituent parts using
Split By Attributes (Analysis)—ArcGIS Pro | Documentation
... sort of retired...
Davec43
Thanks, that seems to be the path. Only issue is there's multiple overlapping with different names.
