How to autoload a toolbox in python ArcGis Pro 2.6
1958
12-11-2020 05:30 AM
servicesigu
I've build a python toolbox stored in the directory "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\sigupy\esri\toolboxes", so that it can be loaded as a system toolbox.
Is there a way to load this toolbox automatically in the python interprter windows ?
Thanks in advance for your reply.
SF
DanPatterson
If you want to store the toolbox within Pro's toolbox structure, they provide some guidance here
Extending geoprocessing through Python modules—ArcGIS Pro | Documentation
and here
Adding toolboxes in Python—ArcGIS Pro | Documentation
otherwise, you can just store your toolbox in the folder path of your project which won't help with other projects however
... sort of retired...
DanPatterson
As an addendum, you could set a default toolbox if you structure your folders for new projects
Change project settings—ArcGIS Pro | Documentation
