How to Adjust Elevation in an OpenStreetMap 3D Basemap to Integrate a 3D Model of an Excavation
1514
06-11-2024 02:20 PM
PauloSantosBIM
I added a 3D model to a map that uses the 3D basemap from OpenStreetMap. However, there is an excavation at the location, and I would like to represent this using the 3D model, but I'm having trouble with this basemap. How can I adjust the elevation in this area of the basemap so that it cuts out the 3D model and uses the elevation from the model in this spot?
Taren_Esri
Hi @PauloSantosBIM
Could you try using a local DEM as the elevation surface instead of the default?
Taren_Esri
Hi @PauloSantosBIM
PauloSantosBIM
Hi Taren, I've tryed this way and I think this might be the only possible way.
It works. Thank you for your feedback
