How to add more than 5 class breaks for data classification in ArcGIS Pro?
3544
09-28-2021 06:04 AM
DiannaFarrell
I need 6 class breaks to classify my data in ArcGIS Pro 2.4.
When I select Manual Interval, there are 5 class breaks. In Symbology,  can add a 6th break in the Histogram tab, but when I return to the Classes Tab, the 6th break is not there.
How can I save the 6th class break?
Thank you
jcarlson
Can you provide screenshots of this? I don't have 2.4 installed to replicate this issue exactly, but when I add breaks to Manual Intervals on the histogram, the Classes update accordingly.
- Josh Carlson
Kendall County GIS
David_Brooks
MVP Regular Contributor
@DiannaFarrell just select natural breaks as the classification method initially, where you can define your intervals, and then switch back to manual and you'll still have the 6 intervals
David
..Maps with no limits..
DiannaFarrell
Thank you! I'll give that a try.
Dianna
