How to add a clickable URL in a popup (attribute rule / Arcade expression) that zooms to another feature.
1518
05-01-2026 12:34 PM
JoseSanchez
Good afternoon,
I’m looking for a way to show the nearest parking location (point layer) when clicking on a restaurant (point layer). I’d like the pop‑up in ArcGIS Pro to display a clickable URL or an Arcade expression that zooms to the nearest parking feature. The layer restaurant  already includes a NEARME field that stores the ID and distance of the closest parking point.
Tried thos code as an expression and it does not work:
var parkingOID = $feature.NEAR_FID;
if (IsEmpty(parkingOID)) {
return "No parking location found.";
var layer = FeatureSetByName($map, "Parking_Locations", ["OBJECTID"], false);
var parkingFeature = First(Filter(layer, "OBJECTID = " + parkingOID));
if (IsEmpty(parkingFeature)) {
return "Parking location not found in layer.";
// Build a link that auto-selects/highlights the parking feature
var url = "arcgis://select/?layer=Parking_Locations&objectid=" + parkingOID;
return "Select Parking Location: " + url;
Robert_LeClair
Esri Esteemed Contributor
I don't know of a usuable workflow to do this in ArcGIS Pro, but I definintely know how to do this in ArcGIS Experience Builder.  Perhaps others will chime in with assistance.
iMike4U
Hey, your logic looks fine but the issue is that ArcGIS pop-ups don’t really support  links like that in most cases. Instead, try using a feature action or configure the pop-up with a related record or custom attribute display rather than forcing a URL. Also double check your layer name in FeatureSetByName matches exactly, that breaks things a lot. If you just want zoom/highlight, setting up a selection action in the map might be a cleaner way than Arcade.
AJR
A bigger picture issue is that using object ids like this (as-if they are long-term persistent record identifiers) is a bad idea.  If you really want a feature id that stays with the record, look at using some other id field (or a guid) that you manage/maintain.  The esri object id values can change at any time (e.g. when the data is exported/imported).
Robert_LeClair
To add to @AJR 's comment about unique ids and not using ObjectID's, there is a workflow to configure a database sequence in this Tech Support article - Configure a Unique ID in a Feature Class That Auto-Increments by a Certain Number
