How to add a clickable URL in a popup (attribute rule / Arcade expression) that zooms to another feature.
1025
Friday
JoseSanchez
Good afternoon,
I’m looking for a way to show the nearest parking location (point layer) when clicking on a restaurant (point layer). I’d like the pop‑up in ArcGIS Pro to display a clickable URL or an Arcade expression that zooms to the nearest parking feature. The layer restaurant  already includes a NEARME field that stores the ID and distance of the closest parking point.
Tried thos code as an expression and it does not work:
var parkingOID = $feature.NEAR_FID;
if (IsEmpty(parkingOID)) {
return "No parking location found.";
var layer = FeatureSetByName($map, "Parking_Locations", ["OBJECTID"], false);
var parkingFeature = First(Filter(layer, "OBJECTID = " + parkingOID));
if (IsEmpty(parkingFeature)) {
return "Parking location not found in layer.";
// Build a link that auto-selects/highlights the parking feature
var url = "arcgis://select/?layer=Parking_Locations&objectid=" + parkingOID;
return "Select Parking Location: " + url;
Robert_LeClair
Esri Esteemed Contributor
I don't know of a usuable workflow to do this in ArcGIS Pro, but I definintely know how to do this in ArcGIS Experience Builder.  Perhaps others will chime in with assistance.
iMike4U
New Member
Hey, your logic looks fine but the issue is that ArcGIS pop-ups don’t really support  links like that in most cases. Instead, try using a feature action or configure the pop-up with a related record or custom attribute display rather than forcing a URL. Also double check your layer name in FeatureSetByName matches exactly, that breaks things a lot. If you just want zoom/highlight, setting up a selection action in the map might be a cleaner way than Arcade.
