How exactly does Sample (Spatial analysis tools) work
200
08-11-2025 09:55 AM
Ben4
Hi All,
Sorry if this is a silly question but I am having trouble digesting the ArcGIS Pro website. Do you all know exactly how the Sample tool works, I'm having trouble and cant understand. Does it take the value of the center cell within a polygon, or is it taking the mean of all the cells within the polygon? If anyone else has experience with it and can explain what is going on that would be super helpful!
Ben
DanPatterson
Sample (Spatial Analyst)—ArcGIS Pro | Documentation
How Sample works—ArcGIS Pro | Documentation
Locations are defined by the input type as described in the 4th bullet point.
Perhaps you could clarify whether you are using a raster, points or polyline/polygon as inputs.
The latter has a qualifier.
The mean value of all cells that intersect each polyline or polygon will be calculated if the input is a two-dimensional raster or multiple rasters. Additional statistic types can be specified if the input is a multidimensional raster and is processed as multidimensional.
the second link explains subtlies for multidimensional rasters etc.
... sort of retired...
Ben4
Hi Dan,
I am using a polygon, as my input to sample a raster. Does this mean that sample is taking a mean of all cells intersecting and within the polygon? Is the value that Sample returns a Mean of all of the means of all the cells or is it a mean of all the cells?
Ben
DanPatterson
Are you not getting multiple locations for your polygon input featureclass?
Run a quick test with your data.
Select one polygon. export it to its own featureclass.  Compare to your other run.
Also, check the help again
way down
If the Generate Feature Class parameter is checked (generate_feature_class = "FEATURE_CLASS" in Python), the output is a point feature class with the sampled values in its attribute table......
Raster—Points will be created using the location of the cell center.
Point—A point will be created at each of the point locations.
Polyline or polygon—A point will be created at each polygon or polyline centroid.
