When I switched maps in a layout, how do I stop the legend text size from changing? Same applies to patches.
They seem to revert to the default. If there a setting within the map itself that governs this or is it just the why ESRI designed the software to work?
I'm hoping there is a solution because it's annoying.
interestingly the text wrapping value persists and doesn't change.
Hi Tim,
When you switch maps are there more, or less layers that the updated legend now has to accommodate? What is the fitting strategy for the legend? If the fitting strategy is such that font size is to be adjusted and the layers in the new map that the legend is pointing to are not the same, then it is expected that the font size may change - as the fitting strategy implies.
If you are unfamiliar with the fitting strategies please see Work with a legend—Layouts | Documentation fro more information.
If you want the font size to remain constant I would recommend using Adjust frame, or Adjust columns depending on which direction, vertical or horizontal, that you want your legend to flow as items (layers in the map) are added or removed.
Hope this helps,
Tom
Hi. I have a similar Problem that I am unable so solve for about forever.
I want to create a dynamic Layout, that I can juse for most maps and do not have to adjust every time. Since ArcGIS does not offer the possibility to add a text field with a decent looking background that adjusts to the title of the Layout I integrated the title into the legend.
The idea is, that the legend grows upwards when stuff is added...
Buuuuuuuut, if it turns out that if the title gets to short... the legend shrinks in width.
This was probably my 100th attempt to solve this problem. None of the different fitting strategies have any (good) effect on this. Is there some workaround that I am missing? I cannot believe there is no solution to make automated map produktion not look like they are from 1950 or having to dial in everything by hand...
I would really appreciate some help with this.
I am facing the same issues. After dealing with Pro for about 5 months now, and calling support nearly every day since (literally, this is not an exaggeration), it is my opinion that Pro is very much still in BETA, was never fully tested and should NEVER have been released. I have so far identified about 20 bugs including what esri calls equivalency bugs (what was in ArcMap is not available in Pro), and have suggested about as many separate enhancement requests because of design (and lack thereof) - it is painfully obvious that they chose form over function when programming this thing, focusing far too much on the ribbons.
And this thing has been out 10+ years now!!
It's like the program has been written by someone who has never drawn a map before.
