How do I prevent duplicating code value in domain
3234
7
05-08-2023 08:57 AM
PLadd
I use coded domains for all of my streets (900+ records - don't judge me).  When I need to add a new street to the domain table, I want to use the next available number.  I know I can sort by code, scroll down to the end and add one to the last number for my new record.
My question is how do I avoid duplicating a number in the coded value field that is already being used?
I tested what might happen by adding a new record duplicating and existing coded value.  I was surprised I didn't get a popup warning me I was violating data integrity.  I believe what happens is that the original coded value gets deleted.
RhettZufelt
MVP Notable Contributor
How are you trying to 'add' it?  Pro warns me and greys out the save button if I have duplicates.
R_
PLadd
I go to the bottom of the list of domains, add a new record
and click the Save button.  The save takes.
Then when I query the coded value in a feature class and the new domain value shows.
Then I close/open the domain table and "WALLINGFORD LINE" is gone and only "test" remains:
RhettZufelt
OIC, I learned decades ago to not use numeric Domains for text fields in ESRI (mainly for lookup issues across software/platforms, but now yet another reason), so when I saw street names (though you clearly mentioned the number), didn't think to test that.
However, using numeric fields I can reproduce your issue in both 2.9.3 and 3.1.1.....
If I set up a domain with Long/Short, add an existing domain to it and save, it WILL overwrite the current value with no error/warning at all.
Probably best to start a tech support call with ESRI on this so it can get in the que to eventually, maybe, think about fixing it.
R_
PLadd
@RhettZufelt I appreciate you taking the time to look into this and identifying the underlying issue.  I will start a tech support case and follow-up here if anything comes of it.
RhettZufelt
@PLadd
Upon furthur testing, I see both the GP tool (Table to Domain) and arcpy.management.TableToDomain both work as expected, and will give an error if you try to append a duplicate domain value.
Might be a workaround in the meantime.
R_
PLadd
Yes, this is a good workaround.  I can setup a temp table to be used with Table to Domain and append it to the appropriate domain as needed.
Here's the error I got doing Table to Domain (append) that I would expect if I were simply editing an existing domain value.  Thanks again @RhettZufelt.
PLadd
ESRI has escalated this to  #BUG-000158369
