How do I import a map (mxd) from and external drive
1666
05-03-2021 08:55 AM
LilianaGuerra
Hi everyone
I relatively new to ArcGIS Pro, I only used the previous ArcGIS versions so far, having done a few Courses to get started with this new Pro version (currently using 2.5).
I am having difficulties understanding how can I import a map (*mxd) (previously done in another ArcGIS version) that is stored in an external drive, once my only options are "My Computer" "Portal" and "Project".
I have an old computer that does not have a lot of space remaining, so all my files are stored in an external driver, and I used to work from there just fine.
Can anyone help?
Thanks in advance
DavidPike
MVP Notable Contributor
Your external drive will be listed under My Computer if properly connected
Import an ArcMap document—ArcGIS Pro | Documentation
DavidPike
LilianaGuerra
Thank you David!
