Table A: I have a file geodatabase table that with a text field (A-F) with a length set to 2000.
Table B: I have a "Personal Geodatabase Table" (very old version of Geographix) that I have joined to table A.
Table B contains a text field (B-F) with length 2,147,483,647, however the data is never more that 1,500 characters.
I need to copy data from B-F to A-F. I am using Field Calculate to attempt this, however the data is being truncated at 250 characters.
Further testing: Using Field Calculate and simply putting a string of more than 250 characters will get truncated if two table are joined. If I remove the join, the string gets load in the field properly.
Is seems when the tables are joined, there is a 250 character limit on text fields. What have I done wrong to cause this.
ArcMap 10.5.1.7333
Jeff
After installing 10.6 the problem went away. I don't know if 10.6 fixed the problem or re-starting my workstation fixed it, but it is now working as expected.
