How can I reverse these values for my legend?? (Using the Heatmap Symbolog on ArcGIS Pro)
4002
03-09-2020 08:04 AM
by Anonymous User
Not applicable
I would like 'Dense' to be at the top and 'Sparse' to be at the bottom.
RobertBorchert
Honored Contributor
Just change the properties of the Color Scheme
Select the Color Scheme expand the list and then select format color scheme
Select the circled buttons  and change the colors around
KoryKramer
Esri Esteemed Contributor
That's the reverse the color scheme:
Is this available to you by right-clicking in the contents pane?
To answer "I would like 'Dense' to be at the top and 'Sparse' to be at the bottom" either right-click > Edit value, or simply double-click the value to rename it:
Katie_Clark
MVP Regular Contributor
Kory Kramer‌, in your last screenshot/animation, that allows you to manually change the word that's displayed, but in this case it seems that isn't helpful because now "Sparse" is associated with values close to 1.00, and "Dense" for values close to 0.00
Is there a way to flip the entire thing? I looked into it and couldn't find any other options or features besides the ones you describe...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
KoryKramer
You're right!  I tried doing something similar by changing the values, but it doesn't appear to stick.  Maybe this is a good one for ArcGIS Ideas
