How can I do batch processing of idw using modelbuilder?
1349
04-15-2018 02:26 PM
FaridaKhatoon
Can I use iterator for the same? Then which one- feature selection?
DanPatterson_Retired
Are you iterating featureclasses?
http://pro.arcgis.com/en/pro-app/tool-reference/modelbuilder-toolbox/iterate-feature-classes.htm
or what are you using as input into your model?
You could always do one manually, then get the script sample from the Results (Geoprocessing results) to form the basis for a script
