Hosted feature layers updated through Arcpro causes offset
1334
09-09-2024 11:56 AM
Labels (2)
Jmoll
As the title says, when I go to update vertices on a hosted line feature layer through Arcgis Pro, the features have an offset and will not go to the proper spot, even if I re-move them multiple times. When I view the layer in AGOL the data saves with this 'offset'. (So it is not a visual glitch in pro) I haven't had this problem in the past with this layer. Has anyone else experienced this before?
George_Thompson
Esri Notable Contributor
Is the offset the same across all the data that is added?
Sounds like a projection thing.... not sure I have seen / heard of that one yet.
--- George T.
George_Thompson
--- George T.
Jmoll
Yes, it was an issue with the projection. Thanks!
