High Resolution Image in ArcScene
4908
03-21-2015 07:38 PM
PaulCote2
Sorry for Cross posting, I realized that this should have been filed in the ArcGIS Professional "place" in geonet.
Has anyone been able to get a high-resolution image to render on terrain in an arcGIS Pro 3D scene?  I have a 30cm resolution jpeg that looks very nice in the 2d map view, but looks like it is about 20m resolution when it is the 3d scene.  I have allso made a mosaic with overlays defined and built according to the default settings, and still no go.
I have seen the esri demonstrations that appear to be using high-resolution groundplan images.  What am I missing?
Thanks
Tags (1)
JeremyWright
What resolution is your elevation source, and in what spatial ref?  Also, are you using a Global Scene or a "Local" (fishtank) scene?
Also - have you contacted technical support?
