Hiding Polygon Shape Files within one Attribute Table
2854
01-17-2024 11:22 AM
WyattCharter
Is it possible to hide specific polygon shape files within the same feature class/attribute table? I'm currently only aware of being able to check and uncheck entire feature classes at a time. I am currently building maps for a farming opertion and have my polygon files split up by crop type (rice, almonds, etc) , but I would like to be able to hide all but one polygon shape file within that crops specific feature class for field specific maps.
BobBooth1
Yes, in ArcGIS Pro you can use a definition query to show only features that match a query.
https://pro.arcgis.com/en/pro-app/3.1/help/mapping/layer-properties/definition-query.htm
clt_cabq
If you want to display only one crop type for instance, you can add a 'definition query' where you would construct an expression that says "crop type = 'rice' " - when applied it will show only rice crops. You can copy/paste that layer then and then edit each definition query to show only the crops you want to show when a given layer is checked on. You find the definition query under the layer properties (when you right click on a layer, its the bottom most selection, then you will see the properties panel with the def query option as below:
