Help with if statement in Aracde
1523
03-30-2020 06:37 AM
RobertBorchert
Honored Contributor
I have a number of vehicles being tracked and the label field is a number for the Truck number.
I would to label the trucks based on who the assigned driver is.
The label field looks like
166 - PU HD
166 being the truck number. and I want to label is as "VOSS".  In Pro it is just fine to make label classes based on the truck numbers, but the map will not carry over to a web map.  Unless there is a way to make label classes for a web map
So I want to do
if($feature.label = "166 - PU HD", "VOSS", (if($feature.label = "186 - PU HD", "LANGLEY","none"))
I have looked at a number of examples but the are not working.
JakeSkinner
Esri Esteemed Contributor
Hey Robert,
Try the following:
IIf($feature.label == "166 - PU HD", "VOSS", "LANGLEY")‍‍‍‍
Ex:
RobertBorchert
Honored Contributor
thanks that's helped.
I am able to then continue on  with multiple iif statements.  I have 12 trucks to label
IIf($feature.label == "166 - PU HD", "VOSS", iif($feature.label == "154 - SUV HD","LANGLEY","None"))
KenBuja
MVP Esteemed Contributor
If you have that many items, you should consider using a dictionary.
https://community.esri.com/message/856040-re-use-dictionary-to-configure-pop-up
RobertBorchert
Honored Contributor
I have never tried using a dictionary but I will look into it.
However, I was able to solve the issue. I asked our GIS Lead about creating a domain out of the driver_id and putting that in.  That actually was something he had thought we should do as there are other departments that use our AVL web map and others wanted to see names rather than truck numbers.  The Driver ID field in our AVL is a long integer field.  Adding a domain took a few seconds.
