HELP - need to map distance in miles from multiple zip codes!
1663
05-02-2021 06:58 PM
Labels (3)
VictoriaKiker1
I am working off of ArcGIS Pro 2.7.0. I am trying to find the distance in miles from multiple zip codes to a school. Any help would be beneficial!
DavidPike
MVP Notable Contributor
Do you have the ZIP codes as a feature? Do you want the distance to the closest part of the ZIP code, the furthest, or the centroid?
Near Analysis or Generate Near Table (Analysis)—ArcGIS Pro | Documentation
would be the ticket.
VictoriaKiker1
Thank you! NEAR_DISTNEAR_DISTHow do I simplify them down? I'm getting big numbers.
DavidPike
I'm not sure what you mean.  What projection/coordinate system is the map and data in?
It would be values of those units of measure, I suspect meters in this case i.e. 16036m -> 16.036km, use the measure tool to check this.
