Help - Merging Point Features
2504
5
03-13-2023 03:40 PM
EvaSlevin
Hi, I'm using ArcGIS Pro for undergraduate research, and am trying to map a dataset which is in three different coordinate systems (Irish Transverse Mercator, Irish Grid, WGS). This dataset should produce a map showing point data.
As ArcGIS doesn't allow for multiple coordinate systems in one dataset, I split the csv file containing the data into three separate csv files. I input these into ArcGIS and projected them into the ITM coordinate system matching my basemap.
Here's where my problem comes in, when I try to merge these three sets of point data using the merge feature, half of the dataset appears to have null values. I'm not sure what I'm doing wrong. Please find attached an image of what I'm inputting into the merge function, and what is coming out.
EvaSlevin
DavidPike
MVP Notable Contributor
Are the field names and field data type the same across the merged datasets?  Otherwise obviously there would be null values from one dataset which doesn't match the same field name or type and a new field has to be added to the merged output.  There's not quite enough info to go on from your current screenshots.
EvaSlevin
Hi David, the field names are identical across all three datasets, as they come from the same original csv file split into three. It's possible it's recognising different field data types for each dataset which I'm looking into. Thanks for your response!
EvaSlevin
Updating this, I think it is a field data type issue, but the issue is that the coordinate systems are completely different so it's recognising the East and North data in one dataset as double, and the other two as long. I've tried creating a new field and copying it over, as I can't edit the type directly, and it won't copy over the digits after the decimal place, which is an issue as it's longitude and latitude.
DavidPike
Can you screenshot the attribute tables and data type of each table.
