Hello,
I am currently doing a project but facing some problems with creating a dgb from "raw" data.
The theme of the task is:
To create a spatial representation of the data for municipal kindergartens, nurseries, and combined childcare facilities within the territory of Sofia Municipality. Spatial analyses should be conducted to highlight the shortage of this type of educational institution, by visualizing the available information and creating additional indicators – e.g., the number of kindergartens per 1,000 children, the number of kindergartens per 1,000 sq. m, and others.
Useful links:
Data for Sofia from Geoplan - https://sofiaplan.bg/api/
• Current register of municipal kindergartens, nurseries, and combined childcare facilities - https://kg.sofia.bg/#/kindergartens
• Layer with the districts of Sofia - https://www.arcgis.com/home/item.html?id=1b492d1982d747dda234175447f7f206#overview - available in ArcGIS Pro and ArcGIS Online
• Report on the population by districts - https://www.nsi.bg/tsb/wp-content/uploads/2023/01/Census2021-Sofia_TI2_comments_AA_M%D0%9A-1.pdf
Thank you in advance!
Solved! Go to Solution.
Please also make sure the values are matching and no case issues.
Hi @МартинТабанджов,
Are you trying to create a "gdb" file?
The provided links are in different language and not able to understand.
Please provide the error message in English, I will try to help you.
Hello,
Thank you for responding!
I am struggling with making a cvs file with the population by regions, and a project package with all the layers.
I am sending the regions layer, as well as an Excel table with the addresses of the kindergartens and their names, and a table with the population by regions:
The problem that I am particularly facing is when I try to Join the population file with the regions layer in the attribute table it shows <null> on population. I can manage to geocode the adresses of the kindergartens.
Could you possibly help me with creating the cvs file with the population and the project package and create additional indicators – e.g., the number of kindergartens per 1,000 children, the number of kindergartens per 1,000 sq. m.
https://services4.arcgis.com/7mKrrPSfzHnGVL0W/arcgis/rest/services/SofiaRegions/FeatureServer
I am available now to meet.
https://topmate.io/venkatakondepati
Please schedule a meeting using the URL above so we can look at it together. I don't have access to software at the moment, but I can guide you if you setup a meeting.
Regards,
Venkat
I am really sorry to inform you that I am not currently available for a meeting, but am really thankful for your understanding and approach towards my situation.
Regards,
No problem. You can always contact if you need help.
Hello again,
Again I am facing problems with joining the population table to the main layer. For some reason its not lettin me to join and relate the dataScreenshot 2026-01-18 161410.png
I think you are trying to do at a group layer instead of feature layer.
Please expand the basic_data and try. It should so you the options.
or you can also get join tool using steps below.
Open the Tool: Go to the Analysis tab > Tools and search for Add Join.
Please let me know if this helps.
