Goodmorning,
Have a .crf layer with "relative humidity" data with 12 StdTime sliced, 1 slice for every month.
Now I am trying to transfer this .crf to a NetCdf, however using the copy raster tool results in error 999999.
Anyone any idea how to fix this? Or an alternative way to go about this?
Thank you.
Copy Raster (Data Management)—ArcGIS Pro | Documentation
under .... Process as Multidimensional
it says...
Checked—The input will be processed as a multidimensional raster dataset and all slices will be processed to produce a new multidimensional raster dataset. Set the Format parameter to Cloud raster format to use this option.
but you have specified .nc
Haven't tried it but this looks promising
Raster to NetCDF (Multidimension)—ArcGIS Pro | Documentation
Copy raster does work perfectly for copying to.crf, but both options only export 1 slice of the raster when a .nc file is picked.
yes, that is what is says. What about the Raster to NetCDF tool?
Tech Support then. It could be your data or your environment given the error.
