Help creating products using databased information
714
03-08-2022 09:30 PM
Lldroge
Hello,
I have been using ArcGIS pro as a database system for quite a while but have never really played around with creating products/pdfs out of it.
Could anyone tell me if it is possible to create a product which displays graphics a long with certain data that can be pulled from a table that is already ingested?
eg. Creating a pdf for a particular product, but your database table is full of all your products.
So, if I was to use the below table, I would only want to display the properties of 'OBJECT_ID: 3' on my brochure which would include: PARCEL_ID, Owner_Name, DEED_BOOK.
Is there a way to set up a template so that if you wanted to display this information you could just enter in your OBJECT_ID and it would automatically pull these values for your product?
I hope this makes sense, any help would be greatly appreciated.
DanPatterson
MVP Esteemed Contributor
The closest is Report—ArcGIS Pro | Documentation
There will be no "automatically", you have to put one together
... sort of retired...
