Heat Map Weighted by Attribute
5662
02-04-2021 03:44 PM
JessicaMuir
Hello,
I am trying to create a heat map using the values of an attribute rather than the density of points.
I would like to display fine particulate matter level variances to show areas of higher and lower relative concentrations. I have tried using the kernel density tool with similar results to the traditional heat map symbology.
If anyone has advice for how to create a heat map weighted by attribute, it would be much appreciated.
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
Heat map symbology in ArcGIS Pro will do this.  You can use a field - particulate matter - to use for the heat map symbology.  It basically creates an on-the fly density raster.
