In ArcGIS Pro, is there an easy way to grey out the surrounding raster area around a "light of day" rectangle?
Idea: Draw attention to an area of a map by fading the periphery
The easiest approach would be to duplicate the raster layer, clip the top copy to your desired 'Light Of Day' rectangle, and then remove color bands from the bottom raster.
This should be the simplest way to get everything inside the Light Of Day rectangle to stay full color while everything outside appears greyed-out.
The Clip function—ArcGIS Pro | Documentation raster function in ArcGIS Pro could also be a solid workflow to consider too. Use the Inside/Outside parameter to screen out the surrounding AOI/box. Place the new result in-memory layer on top of the original then set a transparency for the original layer.
Not quite what you asked, but we often need to do something similar, with a greyed out "reverse mask" around various watershed polygons. We have this function set up to turn any polygon / feature class into a cutout of itself, inside a circular buffer of whatever distance. If you pass it fields, you can use these reverse masks inside a Map Series too, to highlight specific regions as you loop through.
This would require that your graphics layer be a feature class.
import arcpy
import os
def create_reverse_mask(input_fc, output_name, buffer_dist=10000, fields=[]):
Creates a 'cutout' mask from input polygons and adds it to the map
with 75% transparent grey symbology.
input_fc : Layer in TOC, or path to feature class
output_name : Can be a full path, or just the name (in which case, save to scratchGDB)
buffer_dist : Map Units. Set as big as needed for layout
fields : Define the fields to copy over from input (or leave empty)
# Prevent double-adding to TOC
arcpy.env.addOutputsToMap = False
# --- Path Handling ---
if os.path.isabs(output_name):
out_dir = os.path.dirname(output_name)
out_base = os.path.basename(output_name)
output_fc = output_name
else:
out_dir = arcpy.env.scratchGDB
out_base = output_name
output_fc = os.path.join(out_dir, out_base)
# --- Initialize Feature Class ---
if not arcpy.Exists(output_fc):
sr = arcpy.Describe(input_fc).spatialReference
arcpy.management.CreateFeatureclass(
out_path=out_dir,
out_name=out_base,
geometry_type="POLYGON",
template=input_fc,
spatial_reference=sr
print(f"Created: {output_fc}")
# --- Processing ---
cursor_fields = ["SHAPE@"] + fields
with arcpy.da.InsertCursor(output_fc, cursor_fields) as i_cursor:
with arcpy.da.SearchCursor(input_fc, cursor_fields) as s_cursor:
for row in s_cursor:
geom = row[0]
if geom:
buff = geom.buffer(buffer_dist)
mask_geom = buff.difference(geom)
i_cursor.insertRow((mask_geom,) + row[1:])
# --- Symbology (CIM) ---
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.activeMap
# Manually add the layer so we can grab the object
new_lyr = m.addDataFromPath(output_fc)
cim = new_lyr.getDefinition('V3')
# 25% Opaque = 75% Transparent
grey_fill = [128, 128, 128, 25]
# Iterate through symbol layers to update fill and disable stroke
for sl in cim.renderer.symbol.symbol.symbolLayers:
if isinstance(sl, arcpy.cim.CIMSolidFill):
sl.color.values = grey_fill
if isinstance(sl, arcpy.cim.CIMSolidStroke):
sl.enable = False
new_lyr.setDefinition(cim)
print(f"Done. Layer '{out_base}' added.")
# Example Call:
#create_reverse_mask("lightofdaypolygon", "reversemask", 100000)
