Google Earth as a Basemap within Pro
7284
7
07-22-2025 11:52 AM
MillionMap
I was at the user conference last week and heard in a session that Google Earth will now be a basemap selection within Pro.  "As of this conference" it'll be an option in Pro but later in the year for scene viewer.  I even asked for verification at the 'any questions' part of the session, and it was verified by the presenter.  If this is so, how do I bring it into Arc Pro?
Andrew--Johnson
Looks like it's not working because you are on version 3.4.3. This a new feature in ArcGIS Pro 3.5 so please update to that version in order to use it.
thanks!
Andrew
Melissa_B
I don't know about the new feature or basemap option, but if you want to add it into ArcGIS Pro (for a map or a scene), use this URL:
https://mt1.google.com/vt/lyrs=s&x={x}&y={y}&z={z}
You can also add places and maps the same way by changing the layer query in the URL.
Source: https://socalgis.org/2019/11/06/add-google-maps-to-qgis-3/
Edit: You might also consult their terms of service and make sure nothing you plan to do with it will violate their policy: https://about.google/brand-resource-center/products-and-services/geo-guidelines/
Andrew--Johnson
This blog explains how you can bring the Google Photorealistic Mesh as an operational layer into ArcGIS Pro 3.5
https://www.esri.com/arcgis-blog/products/arcgis-pro/3d-gis/whats-new-with-3d-tile-layers-arcgis-pro...
We are currently targeting next release of ArcGIS Pro to have it available as a 3D basemap in the basemap gallery.
thanks,
Andrew
MillionMap
Thank you for the reply but my every attempt gives me this prompt.
Andrew--Johnson
Which version of ArcGIS Pro are you using? Also, you confirmed you are using the correct API key you purchased from Google?
thanks,
Andrew
MillionMap
Running ArcGIS Pro 3.4.3
The world of API keys is a new venture for me, so learning as I go along.  I've set everything up, select what I think I need, I get provided with a key but still no success when I use it in Arc.  There are so many APIs and Services, I'm not sure if I'm choosing the correct one.
Andrew--Johnson
thanks!
Andrew
MillionMap
Upgraded to 3.5 and it solved the issue.  Thanks.
