Glitch using Split tool in pro
932
07-23-2020 11:59 AM
by Anonymous User
Not applicable
When I edit polygons in a portal hosted Feature Service using Split, it appears to randomly create table records with no feature geometry in addition to performing the normal task.
MichaelVolz
Esteemed Contributor
Would you say that this thread is dealing with the same issue?
https://community.esri.com/message/940960-pro-252-polygon-splits-create-null-geometry-records
by Anonymous User
Not applicable
Hey levesqueaj!
This article may be helpful, perhaps its describing a similar issue - Problem: A polygon split outputs polygons with null values in the attribute table in ArcGIS Pro
