Getting edits to show up immediately ArcGIS Pro
2508
11
11-08-2019 10:07 AM
DavidBuehler
Disclaimer, I am really new to ArcGIS Pro.
I am attempting to edit a new feature class created in a file geodatabase.  What is vexing me is I draw a polygon or I cut one, and the edits are not instantaneously seen like in ArcMap.  I have to hit save and then pan or zoom to get the edit to show up.
Notice there are 12 features selected after I cut the six polygons.  There are only the original 6 polygons "selected" on screen.
I should not have to save the edits to see them.  It should work like ArcMap where you cut something or create something and you see it right way.  So what am I doing wrong? I am using 2.4.2 for Pro
ArcPro edits not seen
Tags (3)
Scott_Harris
Thanks, Byron. Should you happen to see this issue again, and you are using 2.5, please let us know. -Scott
MatthewSackrison
Seeing this happen in 3.3.1. Not a new feature class and the gdb is local, not on a network drive. Clearing the cache fixed it, but I could see that causing trouble/confusion.
