Getting an error 000594 when trying to convert a point feature class from shapefile to GDB
4835
11
02-24-2021 07:23 AM
JustinJohnston
Hi Everyone,
I am having trouble converting a shapefile of a point feature class to my GDB.  I have tried the Feature Class to Geodatabase tool, tried first using Feature Class to Shapefile tool then to GDB, tried Feature Class to Feature Class tool.  All of them are producing an empty Feature Class.  I get the following error when running the tools...
000594: Input feature <value>: <value>.—ArcGIS Pro | Documentation
I have confirmed that all of the domain items are set to "Same as Input".  I have tried to use a different Feature Class' domain to see if that would cover the feature class I am trying to convert, but still the same error.  Feature Class to Shapefile works fine, but can't convert to GDB for some reason.  Any ideas on what I can try to get this to work?
DanPatterson
MVP Esteemed Contributor
If you zoom to full extent... what happens?
If you zoom way out, then "clip" your features to a smaller extent.
... sort of retired...
JoeBorgione
Any chance you can zip up your shapefile and attach it here?
