Geoprocessing Tool Execution Trouble
1112
02-01-2023 12:41 PM
GrantHague1
I use the Extract Data Task to extract shapefiles in a specified area...or I did until switching to ArcGIS Pro from ArcMap. I have all the extensions necessary to access the Extract Data Task, but when the tool is run the loading bar forever stays loading. The same thing happens with the Append, Clip, and a few other tools. What are some things I could try to fix this issue?
Robert_LeClair
Esri Esteemed Contributor
A couple things to try:
