Geoprocessing Create Space Time Cube By Aggregating Points Tool has failed
1565
03-19-2025 12:42 PM
PhilipNalla1
Hello Everyone, I keep getting this message whenever I try to use the "Create Space Time Cube By Aggregating Points" which has not happened before.
Geoprocessing Create Space Time Cube By Aggregating Points Tool has failed to open × 'stpm.CreateSpace TimeCube' Load Python Toolbox
Thank you guys for you support
DanPatterson
MVP Esteemed Contributor
Create Space Time Cube By Aggregating Points (Space Time Pattern Mining)—ArcGIS Pro | Documentation
projected point data
greater than 60 and less than 2 billion points
Anything in the requirements that might be missing?
Perhaps if this has always worked and this time it didn't you could elaborate on any differences in the datasets, their type, storage locations etc.
... sort of retired...
DanPatterson
PhilipNalla1
Thank you for your response. I had to restore all the temp files I deleted since they were in the recently deleted items, and it worked.
