Geometry cannot have Z values error when packaging a mobile map
9383
23
08-20-2024 04:01 PM
GWThompson
So I am having an issue when packaging a mobile map for offline viewing. This is a package that I normally do every week, but just recently I have started getting the Z value error
unfortunately the error message isn't very helpful, and the log doesn't show much either
Through trial and error I narrowed it down to one layer, and checking out the layer it doesn't have Z or M values enabled, yet I am still getting the error
I've tried creating a new feature class and copying records over, tried deleting the last 2 months of new/edited records. I've ran the repair geometry tool which fixed some lines with short sections, and one null geometry, but still did not solve the problem.
Any ideas???
Miralem_Zeljo
That is really interesting observation. I will be testing this myself.
RoanokeDave
A year later and I'm still looking for a fix. The workaround the I use is to make a temporary file geodatabase, making sure to set the Z values to Disabled!  Then I wrote a model that copies all of the layers into the temp GDB. What makes this less of a pain now is that I can go to my real map with the real feature layers and click Copy, then in the map where I reconstruct everything with the files from the temp GDB I can hit "Paste Properties" and get everything set up like I want. Then package with success.
Jeremy_Z
Not in my case.
GIS - Getting it Surveyed is too expensive.
AveryCook2
I was also having the same error when packaging a project package. None of the layers had Z values or a vertical coordinate system. I was not able to clear the error, but was able to find a work around by selecting the "Upload Package to Online Account" option rather than saving to file. The Project Package tool did not throw an error when packaging and uploading. Then could just download the package from my AGOL account.
