Hi everyone,
I’d like to share Geodiversity Tools, a custom geoprocessing toolbox for ArcGIS Pro designed to calculate partial criteria used in landscape geodiversity assessment.
The tools are intended for landscape analysis, geomorphometry, environmental planning, and scientific research, and are implemented as a reusable and reproducible ArcGIS Pro workflow.
The repository contains:
a custom ArcGIS Pro Toolbox (.atbx)
a collection of Python script tools (.py)
documentation for installation and usage
prepared test data and cartographic symbology
All tools are fully integrated with the ArcGIS Pro GUI and compatible with ModelBuilder.
Vector-based landscape metrics
diversity of polygonal (A) features based on:
number of elements (A_Ne)
number of categories (A_Nc)
Shannon–Weaver diversity index (A_SHDI)
diversity of linear (L) features based on total length (L_Tl)
diversity of point (P) features based on:
number of elements (P_Ne)
number of categories (P_Nc)
Raster-based landscape metrics
diversity of continuous regionalized variables based on:
standard deviation (R_SD)
circular standard deviation (R_SDc)
Steinhaus vertical relief index (R_M)
The tools support grid-based analyses, raster–polygon overlays, and integrated output standardization, ensuring comparability of geodiversity metrics across grids and study areas.
Easy-to-use ArcGIS Pro interface
Clean Python implementation using arcpy and Spatial Analyst
Support for discrete and continuous regionalized variables
Designed for reproducible scientific workflows
Support for file geodatabases (.gdb)
(shapefiles are intentionally not supported)
ArcGIS Pro 3.x
Python 3.x (ArcGIS Pro environment)
Installation instructions: Docs/installation.md
Methodology and index definitions: Docs/GeodiversityTools.pdf
Test datasets: TestData/TestData.md
👉https://github.com/tomaszbartus/GeodiversityTools
Feedback, suggestions, and use cases are very welcome.
Best regards,
Tomasz Bartuś
Author — Geodiversity Tools
Version: 0.2.0
Just explored your manual on github, clearly lots of effort went it to that, I particularly liked the inclusion of the conceptual diagram, a picture says a thousand words!
Thank you for your kind words. Some of the tools are unique. I have ideas for more...
Greetings from Krakow
Tomek
