Geodesic for measuring; Planar for analysis
8760
11
08-02-2023 05:52 PM
Craig_Eissler_Iceman
Measure tool: Geodesic vs. Planar: The Help page indicates "Geodesic" is always more accurate.
OK, but, why do they also indicate that projected coordinate systems are more suited for analysis -- which includes measuring, of course?
In fact, in the Calculate Geometry menu tool (but NOT the ArcGIS toolbox tool) is grayed out, when attempting to measure in geographic coordinates ..this, I understand. How it relates to the other observations, I do not.
Thanks, CCE
DanPatterson
Perhaps you can use this as an example for Tech Support
LL corner  300,000, 5,000,000
UR corner 300, 010, 5,000,010
MTM zone 9  (NAD_1983_CSRS_MTM_9)
... sort of retired...
Thanks again for sharing. Accuracy, or measurement result differences, wasn't my original concern on this Post. However, now I'm starting to see some differences within the same measurement mode and projected coordinate system -- similar to what you illustrated. Also see my results below between the Measure tool and the Shape_geometry fields. ...Close, but not exact. Why not? ...Ok, I'll submit a Case to Esri Support to see what they say.
