Geocoding with Composite Locator - How to return locator used for matches?
1210
03-15-2023 08:20 AM
NSamu
Is there a method that exists for determining what locator was used for matched results of a geocoding service using an ArcGIS composite locator? I'm wondering if it's possible for this info to be programmatically extracted or identified automatically another way? I haven't had any luck finding a method yet. Any input would be much appreciated.
Nicole
MichaelVolz
Esteemed Contributor
Is this an ArcMap composite locator or multi-role ArcGIS Pro locator?
NSamu
It is an ArcMap composite locator but we can make one with Pro if needed.
ShanaBritt
Nicole:
If you have geocoded with a composite locator, the Loc_name field in the output geocode feature class will display the locator in the composite that returned the match. This field is returned when geocoding with a local composite locator or composite geocode service in both ArcMap and  ArcGIS Pro. https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/what-is-included-in-the-geocoded-result...
If you are trying to figure out which geocode service or locator was use to create the geocode result feature class you can look at the properties of the result in ArcMap and the properties dialog would have a Geocoding tab. This is not available in ArcGIS Pro. If you'd like this functionality in ArcGIS Pro, please submit an idea here or enhancement request through Support.
