Generate Points Along Line placing points at incorrect distance
3757
03-14-2023 06:59 AM
VictoriaTousaw
I am trying to generate points along a line that are spaced 100 m apart with points at each end of the line.
I am using the Generate Points Along Line tool, by distance, 100 meters. The output results in points along the line that are placed ~145 m apart in straight sections of the line, and ~115 to 130 m apart around curves in the line. I double checked and the line is all one segment.
Any ideas of ways that I can try to fix this are greatly appreciated!
DanPatterson
MVP Esteemed Contributor
Are you using the measure tool to confirm the placement? and is your map coordinate system set to the web mercator?  If so, choose a projected coordinate system that shows better distance and area measures (like a UTM, state plane, equidistance etc(
... sort of retired...
DanPatterson
VictoriaTousaw
Thanks! After projecting the line and changing the map coordinate system the points were plotted properly.
Has the functionality of this tool been replaced by a different tool?
AnilKumar0
HI Victoria Tousaw ,
Could you kindly share which projection method you employed and the specific map coordinate system to which you changed to ?
Thanks in advance.
DanPatterson
You might want to consider looking into this
Geodetic Densify (Data Management)—ArcGIS Pro | Documentation
