Generate Near tool but using only locations within another layer
2171
07-06-2021 03:49 PM
GISLearner
I have a two datatsets: one containing site locations and another containing Points of Interest. I have used the drive-time tool to create polygons of the area within 15 minute driving time from the site locations. Now, I need a tool to summarize the distance between the site locations and Points of Interest that are within the 15 minute polygons I created. Is there a tool that can do this?
DanPatterson
MVP Esteemed Contributor
Select Layer By Location (Data Management)—ArcGIS Pro | Documentation within a distance of
plus others like
Spatial Join (Analysis)—ArcGIS Pro | Documentation within a distance of...
Also Generate Near Table (Analysis)—ArcGIS Pro | Documentation
Allows you to find more than one feature and you can query for distance thresholds
... sort of retired...
GISLearner
The challenge is I don't have a specific distance - I want the areas (and how far they are from the site locations) within 15 minute drive time
DanPatterson
If you want drive times, then you need to use the spatial analyst extension for this, otherwise you will have to use a guesstimate a straight line distance and buffer your points using this value as the radius
