FYI: Polygon Feature Selection in Pro
1851
09-22-2016 01:10 PM
MichaelMiller8
Thought this may be helpful to some.
It seems that Pro will not select a single hollow (no fill color) polygon by selecting in the interior of the polygon. It will select multiple polygons if you run the selection tool over a boundary.
Selection works fine with filled polygons.
DanPatterson_Retired
That is a 'bug' and should be reported if that is the case, since it will affect the results of manual selections
Robert_LeClair
Esri Esteemed Contributor
What release of ArcGIS Pro are you using?  I'm running 1.3.1 and can select a hollow fill polygon with the select tool clicking in the middle of the polygon.
MichaelMiller8
10.3.1 here. Had a good conversation with support and understand what
happened. Will forward our discussion when I get home. Thanks for your
help!!
