Flow direction using an arrow
3869
10-17-2023 12:20 PM
Zsmith
Hello I'm trying to make an arrow that has the flow direction based off of the 360 degrees of a circle.
so if the flow is to the right, I would select the 90 degree in the attribute table, if that makes sense.
Please someone help me. I'm also using arc GIS pro
Hillary_E
Hi @Zsmith ,
Are you hoping to symbolize a polyline feature class? You can symbolize based on Unique values and choose an Arrow Line to show the direction of flow.
I hope this helps!
AyanPalit
@Zsmith The following documentation should help:
Vary symbology by rotation
Ayan Palit | Principal Consultant Esri
